Two stage least squares
kungal
Postby kungal » Sun Mar 14, 2010 4:12 am
Does any one know why it seems to be impossible to get the coefficients that EViews estimates in prab by doing prab manually.
I understand that the standard errors should be different but I can't see how EViews is coming up with its parameter estimates either.
Re: Two stage least squares
Postby EViews Gareth » Sun Mar 14, 2010 9:05 am
It is relatively straight forward to mimic the results manually.
Of course it is pretty difficult to tell why you are unable to do it, without knowing what you are doing.
kungal
Postby kungal » Mon Mar 15, 2010 12:01 am
I suppose that would help.
I cannot see what I am doing wrong. I have a set of instruments a, b and c and I regress each of the explanatory variables on a, b and c and click on prab button to create series with the predicted values of each of my explanatory variables. Then I regress my dependent variable on the prab series I have just created. However, the results I obtain are completely different from the results I get if I use the prab option for estimation.
I feel like I must be overlooking something rather important.
Postby EViews Gareth » Mon Mar 15, 2010 8:41 am
create u 100 series x=nrnd series y=nrnd series z=nrnd 'simple 2SLS equation eq2sls.tsls y x @ z equation eq1.ls x z c eq1.fit xf equation eq2.ls y xf
Postby EViews Gareth » Mon Mar 15, 2010 9:02 am
Get's a bit more (and only a bit) if you have one of the regressors as an instrument (which is usually the case, since C is usually both an instrument and a regressor):
create u 100 series y=nrnd series x=nrnd series z=nrnd equation partialy.ls y c z partialy.fit yf equation partialx.ls x c z partialx.fit xf equation tsls.tsls y c x @ z c equation manual.ls yf c xf
kungal
Postby kungal » Tue Mar 16, 2010 5:15 am
Thanks a lot. I got it now
