Hi!
I am trying to run some endogeneity and over identification tests in a couple of models.
First round were excellent.
I then decided to add an additional variable and some updated data, creating a new work file in the process.
Now the I.V menu doesn't appear.
I can go back into the old work file, rerun the same tests and even adapt the model (see eviews image below) but with the new data set, nothing (closest I can get is eviews2 image below). The options I see under GMM are slightly different as well - different boxes and now "GMM and dynamic panel".
I'm sure it is something simple, but..
I.V - Endogeneity tests, GMM, and J Stats
Keith Porter
- Updated data set
- eview2s.png (9.48 KiB) Viewed 6447 times
- Original data set
- eviews.png (22.41 KiB) Viewed 6447 times
Re: I.V - Endogeneity tests, GMM, and J Stats
EViews offers different estimation options based upon whether you are dealing with panel data or not. The updated data is panel, the original is not.
Keith Porter
I appreciate the response, but I am still confused - sorry
The only material difference between the two sets is one additional RHS variable D_E and one more year's worth of observations for one of the other variable.
How does that change it to panel?
Can't answer that for you. But I can tell you that the new data set is a panel workfile. How it became a panel is up to you.
Keith Porter
OK - at least I know I'm not totally nuts!
I appreciate your help
