eViews installation via SCCM
UOB
Postby UOB » Mon Oct 12, 2020 2:24 am
Hi all,
I'm having issues installing eViews 11 through SCCM
We currently deploy through GPO using a batch file that registers the installation, however through SCCM it just isn't installing.
Has anyone else done it and can share their configuration of the Application or Package please?
Many thanks
EDIT: To add to this, it sits are 'Downloading (0% Complete)', other applications are fine and install, so I know its no the environment.
Re: eViews installation via SCCM
Postby EViews Jason » Mon Oct 12, 2020 8:48 am
Can you identify at which point in the deployment you are seeing the "Downloading ..." message? The EViews installer doesn't download any components. All the required components are within the installer. This would have me believe there is an issue with the SCCM configuration.
Please email me at jason@eviews.com for a faster response.
UOB
Postby UOB » Tue Oct 13, 2020 2:49 am
To update:
I've tried running the installer through SCCM with cached content, running it directly from the installer location, running it through Powershell....All sorts.
The installer 'runs' but other than that, it doesn't actually install.
Can anyone who has SCCM, please try and do a test deployment through it? And let me know?
UOB
Postby UOB » Tue Oct 13, 2020 7:30 am
Further update:
Got it working for the most part along with registering the application, only 'issue' is it leaves the 'Registered' window open which is a bit of a pain.
For anyone that cares, in SCCM:
-Create a Standard Application
-For the 'Deployment Type' under the 'Content' tab, leave it blank
--'Programs' tab I have used the following for 'Install':
powershell.exe -executionpolicy Bypass -file \\ServerFQDN\eViewsSoftwareLocation\InstalleViews.ps1
--'Programs' tab I have used the following for 'Uninstall':
MsiExec.exe /X{8B48E17F-1487-4641-8005-802689C290BC}
-'Detection Method' tab I used Registry detection
--Type: Registry
--Hive: HKEY_LOCAL_MACHINE
--Key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
--Value: {8B48E17F-1487-4641-8005-802689C290BC}
--Data Type: String
--Registry Setting must exist
-'User Experience tab' is set to Install for System and Whether or not a user is logged on
Contents of the PowerShell Script:
New-item -Name "TEMPeViewsfiles" -Type Directory -Path "C:\" -Force -Verbose Start-Sleep -s 5 Copy-Item -Path '\\ServerFQDN\eViewsSoftwareLocation\*' -Destination 'C:\TEMPeViewsfiles\' -Verbose Start-Sleep -s 5 & 'C:\TEMPeViewsfiles\EViews11Installer(64-bit).exe' -s '-f1C:\TEMPeViewsfiles\eViewsScript.iss' echo Waiting 60s Start-Sleep -s 60 Write-Host "Attempting to Register eViews installation" & 'C:\Program Files\eViews 11\EViews11_x64.exe' /registerlicense "*Insert - License - Code*" "*Joe Bloggs*" Start-Sleep -s 10 Write-Host "Removing Temporary folder TEMPeViewsFiles from C:" Remove-Item -path C:\TEMPeViewsfiles -Recurse -Verbose Write-Host "If 'True' is displayed below, installation was successful" $TRUE Write-Host "eViews 11 Installed, check exit code below" $LASTEXITCODE
The 'eViewsSoftwareLocation' in the Script contains the eViews.exe file and the created .ISS files (assuming you are using that)
I could probably try and clear it up a bit more but for whatever reason the original batch file didn't want to work, running it from the local SCCM Cache also wasn't working, hence copying it down locally to execute.
One of the main things stopping my original PowerShell tests from working was the license code in the command line didn't have spaces between the ' - ' characters...Yet when recording the installation it didn't seem to complain about it.
Add logging if required.
