Creating a valuemap from labels and numeric codes defined by an alpha and a series in another page
mamo
Postby mamo » Mon Sep 21, 2020 3:28 am
Dear Eviewers ,
I use Eviews 11, Sept 2019 built, 64bit.
Using the workfile created by the example code below, what is the easiest approach to create a valuemap and apply it to the values of the variable "crossid" in the page "data", by using the labels in "label" corresponding to the codes in "code" as defined in the page "valuelables"?
One approach could be to group "label" and "code", freeze the group as a table and create a valuemap by for-looping through the rows of the table as implemented in the code. I am wondering, however, whether there is a more straightforward approach.
mamo
wfcreate(page=data) a 2000 2010 3 pagestruct(none) crossid=crossid^2 pagestruct crossid @date(dateid) pagecreate(page=valuelabels) u 3 series code=@obsid^2 alpha label="label_"+@str(code) ' Here follows a cumbersome approach to create and assign the valuemap ' Can this be simplified ? freeze(mode=overwrite, tab) code label valmap vmap !nr=tab.@rows for !r=3 to !nr !value=@val(tab(!r,2)) %label=tab(!r,3) vmap.append !value %label next pageselect data copy valuelabels\vmap vmap crossid.map vmap
EViews Matt
Re: Creating a valuemap from labels and numeric codes defined by an alpha and a series in another page
Postby EViews Matt » Tue Sep 22, 2020 9:19 am
While you do need a loop to build the valuemap programmatically, you can simplify much of the intermediate work. You can even leave the crossids unmodified, as shown below.
wfcreate(page=data) a 2000 2010 3 vector tmp = @uniquevals(crossid) valmap vmap for !i = 1 to tmp.@rows !value = tmp(!i) %label = "label_" + @str(tmp(!i)^2) vmap.append !value %label next crossid.map vmap delete tmp
mamo
Postby mamo » Tue Sep 22, 2020 11:30 pm
many thanks for the quick reply
The simplifications you are suggesting are obvious with respect to the structure of the concrete dummy data set the example code generates.
However, the question was not meant to relate to the specific data structure of this dummy data but rather to the more general case: there is one page with data (data page), and separate page (labels page) which contains an alpha series carrying the value labels, and another series (or alpha) containing the respective values to be labeled.
I was wondering what would be the best way to map the values of a series (or alpha) in the data page into the corresponding labels as implied by the labels page, looking for a more economical one than generating a table and looping over it.
Best, mamo
EViews Matt
Postby EViews Matt » Wed Sep 23, 2020 1:18 pm
In which case, you can exploit an undocumented feature of the valuemap object's append procedure that lets it process multiple pairs in a single statement. Updating your original example,
wfcreate(page=data) a 2000 2010 3 pagestruct(none) crossid=crossid^2 pagestruct crossid @date(dateid) pagecreate(page=valuelabels) u 3 series code=@obsid^2 alpha label="label_"+@str(code) valmap vmap alpha tmp = @str(code) %tmp = @winterleave(@wjoin(@convert(tmp)), @wjoin(@convert(label))) vmap.append {%tmp} pageselect data copy valuelabels\vmap vmap crossid.map vmap
mamo
Postby mamo » Thu Sep 24, 2020 12:17 am
Great, many thanks!
So kindly document this nice and usefuly feature of the valuemap object explicitly in your next update of the documentation.
Best, mamo
mamo
Postby mamo » Thu Sep 24, 2020 12:41 am
PS: this exploits another apparently undocumented feature, namely, one of the function of @convert(x).
The available documentation requires the argument x to be a numeric series - however, @convert obviously works with an alpha series as well in which case it yields an svector. It would be nice to if this feature can be documented as well.
Funny, though, is the following inconsistency:
This works:
vector myvec=@convert(@sqrt(code))
The following works as well:
alpha temp=@str(code) svector mysvec=@convert(temp)
But the following code doesn't, yielding an ERROR message that @convert requires a numeric argument!
svector mysvec=@convert(@sqrt(code))
This is inconsistent, since both @sqrt(code) and @str(code) are just functions of the series code, generating a series or an alpha series, respectively.
Best mamo
AlyssaMckenzie
Postby AlyssaMckenzie » Fri Jun 11, 2021 10:21 am
[quote="EViefws Matt"]Hello,
wfcreeate(page=data) a 20030 2010 3 vector tmp = @uniquevals(crossid) valmap vmap for !i = 1 to trmp.@rows !value = tmp(!i) %label = "label_" + @str(tmp(!i)^2) vmap.append !value %labelSee option mask() for the different formats. Stata commands that display the value labels also show the associated numeric values. Prefixes are removed with​ . next crossid.map vmap delete tmp
[/queote]See option mask() for the different formats. Stata commands that display the value labels also show the associated numeric values. Prefixes are removed with​ .
