symbol and symbolsize option
Postby tvonbrasch » Sat Mar 21, 2020 11:27 pm
When making a graph with symbols, the symbolsize option seems to override the symbol option, i.e., the command
graphname.setelem symbol(none) symbolsize(small)
will still show symbols even though the option "none" is activated....
Is this a bug?
Example below.
t
wfcreate a 2000 2010 genr x1= nrnd genr x2=1/x1+nrnd genr x3= x1+x2 %lcolorblack="@rgb(55,55,55)" %color1 = "@rgb(249,107,96)" ' red %color2 = "@rgb(66,143, 249)" ' "@rgb(17,115,247)" '"@rgb(54,136,248)" ' blue %color3 = "@rgb(57,172,51)" ' green %color4 = "@rgb(197,192,33)" ' orange 'mønster på grafene %lpat1 = "solid" %lpat2 = "dash4" %lpat3 = "dash9" %lpat4 = "dash1" 'mønster på grafene %symbol1 = "none" %symbol2 = "none" %symbol3 = "none" %symbol4 = "none" %symbolsize="6" 'grå fra 1 til 8 %gr="_d" graph {%gr}.line x1 x2 x3 {%gr}.options linepat for !itersc=1 to 3 !itersccolor=!itersc {%gr}.setelem({!itersc}) lcolor({%color{!itersccolor}}) lwidth(2.1) legend({%legend}) lpat({%lpat{!itersccolor}}) symbol({%symbol{!itersccolor}}) symbolsize({%symbolsize}) '{%gr}.setelem({!itersc}) lcolor({%color{!itersccolor}}) lwidth(2.1) legend({%legend}) lpat({%lpat{!itersccolor}}) symbol(none) 'symbolsize({%symbolsize}) next show {%gr}
Re: symbol and symbolsize option
Postby EViews Jason » Wed Apr 01, 2020 2:16 pm
It's not a bug. It's an order of operation issue. Anytime you specify a symbol size, it is assumed you want symbols on, otherwise why did you specify it?
In your example, 'symbol' was processed prior to 'symbolsize' and so it was turned off but then turned back on when the size was specified.
If you flip the order, the size will be set to small and then turned off.
