Bayesian model averaging
EViews Esther
This thread is about the BMA add-in which accounts for model uncertainty associated with variable selection.
Re: Bayesian model averaging
Hi, I'm trying to use the BMA EViews add-in for model averaging (already used the R counterpart package successfully). Also went through some pages of the Command Reference (pp. 154 onwards) on the requirements to properly run the BMA add-in. I think I've checked all necessities already (rscproxy, statconnDCOM, and R). Couldn't 'sync' it though, for example when I tried the StatConnector Test the error "Method ~ of object '~' failed" kept on showing itself.
Also tried to use a version of RandFriends that I found for an easier install. I thought the bma() EViews function would already work but after a little waiting time a different error popped-up ("R (for bma<-bic.glm(x,...) returned an error; evaluation stopped because of an error"). Could you give some specific recommendations for BMA to work properly in EViews? Thank you.
Sounds like you got it working, it just doesn't work on your particular data.
Hi Gareth. I tried a different EViews workfile, a simple one with 74 time series observations with 15 variables. Utilized the needed commands (e.g. xopen()) to maintain the connection to make sure. My target was to regress a response variable on the rest of the series. The required window appeared after clicking "Add-ins" >>> "BMA for GLM/LM". However after writing the series names on the pertinent box and pressing "OK", the error "R (for 'temp_EViews_depvar') returned an error; internal error: unsupported data format passed to interpreter." popped up.
Tried it using the "bma(method=LM ..." technique as well but I'm getting the same error. Can you advise on a possible workaround to this issue? Is it still possible to execute bayesian model averaging using the BMA add-in despite this?
Thanks,
Edward
Thanks,
Edward
Jamel Saadaoui
Dear Sir,
I have some trouble when I try to use the BMA add-in with Eviews.
When I try to run a regression, Eviews send me an error message "StatConnectorSrv.StatConnector is not connected".
I downloaded the latest version of R and of the BMA package.
Thank you for your help,
Jamel
Jamel
You need to get statconnector working properly. Follow the instructions for installing RExcel here:
http://homepage.univie.ac.at/erich.neuw ... to_install
Jamel Saadaoui
Thank you very much for your help, now it's work perfectly with some data downloaded thanks to getmacrodata add-in.
Jamel
Jamel
When I tried to run the BMA add-in in EViews 8, EViews prompts me the error message "No external connection is open." Any clues why this message is shown, and how to resolve this problem? Thanks.
Do you have R properly installed and working?
Hi everybody (I hope that someone will see this post!)
When I am trying to run BMA the following message appears: "StatConnectorSrv.StatConnector is not registered".
I have downloaded all the necessary libraries in R.
I tried to use the linked suggested before (http://homepage.univie.ac.at/erich.neuw ... to_install),
but I got totally lost!
Any ideas?
Thanks.
Any ideas?
Thanks.
Hi, Gareth,
The link you gave is not active anymore. Could you give a valid link please?
Thanks!
Thanks!
statconnector is no longer required.
