Is there n eviews code for non-linear regression modelling? I am specifically looking for system non-linear least squares (NLSYSTEM) regression modelling code. I read that I could do this in RATs but I do not have access to RATs software.
Re: system non-linear least squares
The ls command does single equation nonlinear. System is used for systems of nonlinear equations.
Yes, I would like to estimate a system of non-linear equations, is this possible in Eviews?
Thanks.
Thanks.
Yes. It's pretty easy. You define an EViews object called a System and then push the estimate button.
Thank you, I will post questions if I face issues in estimating the models, hope you do not mind sparing a few minutes to answer them.
