Greetings
When I try to run the run Gregory Hansen Cointegration Test I get this error:Near singular matrix error. Regressors may be perfectly
collinear in "DO_ GHC.LS Y C (@TREND>6-2) G"[/b].[/u] I have tried all the tricks I know but no solution. I only have 1 dependent variable (exports) and 1 independent variable (imports).
Please assist.
Kind Regards
Nwabisa
Gregory-Hansen Cointegration Test
Re: Gregory-Hansen Cointegration Test
What values do you see for the series
(@TREND>6-2)Re: Gregory-Hansen Cointegration Test
Hi Startz
I also have no idea where is that coming from (@Trend>6-2, it pops up when I run the program. All I know is that I selected REGIME SHIFT model because I want to capture both change in intercept and trend.
Kind Regards
Nwabisa
Kind Regards
Nwabisa
You might want to post your workfile and exact instructions on what you are doing.
Hi Gareth
I have attached my workfile and G-H program. The study examines the sustainability of the current account. The aim of running this test is to find if the long-run relationship exists between exports and imports and account for any structural breaks.
Kind Regards
Nwabisa
Kind Regards
Nwabisa
- real exports and imports.wf1
- (46.48 KiB) Downloaded 829 times
- g_h structural breaks program.prg
- (4.76 KiB) Downloaded 972 times
The problem is that LRX and LRM_ are only defined from 2009 and that @TREND>6-2 is always 1 in this period, hence collinear with the intercept.
As a guess, try setting the smpl to the period in which all your variables are valid.
