I was trying to replicate some estimation results and got an error message that matrix is nearly singular. What needs to be done?
error message: matrix nearly singular
Re: error message: matrix nearly singular
Pretty hard to say without more details. The obvious answer is, you need to figure out what's causing the singular matrix...
Thank you. Would you kindly take a look at the Workfile? We put a reasonably serious amount of work on it.
I am working on estimation of a CCAPM model with FF25 assets. Can it be that high correlation among FF25 asset returns cause a singularity problem? If you kindly comment on this issue I will greatly appreciate.
Co-linear regressors is the most likely cause of singularity in linear models.
