I have a very basic question about saving graphs.
I'm trying to save this attached graph (called graph) as a png file.
The output i get is missing the axis numbers (see attachment called output).
Am i missing a line of code? It PDFs fine (using the print command). But i'm unable to get "graph.save(t=png,w=4.5,h=3.08) c:\output" to work properly.
I've tried changing the width and height
Thank you
Saving Graph
Saving Graph
- Graph.PNG (31.93 KiB) Viewed 6200 times
Re: Saving Graph
Forgot to attach the output file. Here it is
- output.PNG (8.58 KiB) Viewed 6199 times
Re: Saving Graph
Never mind. I tweaked the template using background(black) and that worked.
Re: Saving Graph
We would still like to take a look at the problem and get it fixed. If you don't mind, please send your workfile to jason@eviews.com.
Re: Saving Graph
Ok. Will send you the workfile (and a more detailed explanation) at some point this week, although i think the issues was with my code for the template.
