What are the steps of forecasting realised volatility of swap rates using EViews?
DavidG93
Postby DavidG93 » Sat Aug 18, 2018 1:02 pm
One part of my dissertation involves forecasting the realised volatilities of interest rates. I know that I have to first model the realised variance as a garch process.
So, what I have done so far is, I got the swap rates from 2000-2006. Then, I calculated the logarithmic daily changes of them. Afterwards, I estimated a GARCH 1,1 process (although I am not sure if that was done right).
Then, my next forecast equation (in theory) is rt+h = c0 = c1*rt-1+h + e
rt = logarithmic daily changes
h= forecast period
How do I now forecast the realised variance for the next 10 years e.g.?
Since I am not the best at using EViews, I would appreciate any help/hints/assistance!
pvestia
Re: What are the steps of forecasting realised volatility of swap rates using EViews?
Postby pvestia » Sat Aug 18, 2018 1:24 pm
can you post the workfile?
Is easier to see what you need to do and understand what are you doing.
DavidG93
Postby DavidG93 » Mon Aug 20, 2018 8:07 am
Sure, Sorry I didn't do that earlier!
ForecastSwaps.wf1
(96.57 KiB) Downloaded 386 times
pvestia
Postby pvestia » Mon Aug 20, 2018 9:04 am
Hello David,
After checking the correlogram of rt it seems to follow an ARMA(1,1) which you have to estimate the "rt c ar(1) ma(1)".
After that you need to conduct the Heteroskedasticity Test, which confirms the ARCH effects. so You need to estimate the ARMA(1,1)-GARCH(1,1).
After that to perorm the out-sample forecast, You need to rearrange you range size and than perform the forecast with the method you want and for the sample you want.
I will attache the screenshot explaining and the workfile.
forecastswaps.wf1
(104.81 KiB) Downloaded 372 times
DavidG93
Postby DavidG93 » Mon Aug 20, 2018 10:09 am
Hi pvestia,
Thank you for your quick answer!
I adjusted the range size, however, when I do the dynamic forecast, there is only a straight line from 2006 onward. Any idea why?
If I'm right, I can't use the static forecasting, since I don't have the actual values, correct?
pvestia
Postby pvestia » Mon Aug 20, 2018 2:23 pm
Hello, Yes with the static forecast you are only abble to forecast One-period because you only have an auto-regressive lag. The result of the dynamic forecast in Eviews I don't understand them quite well. They should converge to zero, but is kind of odd being straight line, I don't know is suppose to be like that.
One thing you can do, I'm trying something similar, is to perform multiples static forecasts in a loop. I don't know with this procedure I'm proposing you doesn't generate regressor bias, but you can give it a try.
I will give you a code, I didn't resize the data in my workfile because is irregular and I don't know the dates you want. To use the code you just go to Files\New\Program and then copy and run it.
' number of obseration you added to the range for your forecast ' based on you screen shot the number is 5211-2600=2611 !x = 2611 'THE LOOP STARTS 'define loop for the forecast for !i=1 to !x 'make the ARMA-GARCH smpl @first @first+2598+!i equation arma_garch.arch(1,1) rt c ar(1) ma(1) 'perform the static forecast arma_garch.makemodel(mod1) smpl @first+2599+!i @first+2599+!i mod1.solve(d=s) smpl @all series rt = rt_0 'delete the auxiliar delete rt_0 next
After you done this, you estimate again the ARMA(1,1)-GARCH(1,1) and do a static forecast for the all range and see what you got.
