I'm working with different workfiles and want to switch between them with the WfSelect-command in Eviews10. However, it doesn't seem to work to do that in code but it works if you write it in the command line instead. Is that a bug that you can fix soon?
An example:
Wfcreate(Wf = temp, Page = A) A 1980 2020
Wfcreate(Wf = alt, Page = A) A 1980 2020
WfSelect temp
Best regards,
Pelle
Wfselect
Re: Wfselect
Make sure you have the latest patch for EViews 10. I just ran your program with EViews 10 May 31, 2018 build and the TEMP workfile was placed on top at the end.
