EViews10+: LogSave
nilslh
EViews10+: LogSave
Postby nilslh » Wed May 16, 2018 6:11 am
I have encountered a problem in EViews 10+ (build Apr 24 2018). When just typing
LogSave "[path]"
I get the error message Log name was not found in "LOGSAVE "[path]"". Notice that there is a space after Log name in the error message (does not appear in this post). I do not get any error message using EViews 9.5. Note also that I have not used any command before LogSave, e.g. LogMode or similar. For instance the following works properly:
LogMode -all s Statusline "Test 1" LogSave "[path]"
Regards,
Nils
nilslh
Re: EViews10+: LogSave
Postby nilslh » Wed May 16, 2018 6:54 am
Furthermore, specifying LogMode does not work properly. Both error (e), logmsg (l) and -program (-p) causes EViews to crash in the following context:
LogMode l LogSave "[path]"
However, p works fine for example.
Best,
Nils
EViews Katerina
Postby EViews Katerina » Thu May 17, 2018 1:15 pm
Next patch of EViews10+ will include fixes for the LogSave command issues.
Until next patch, you can still use the LogSave command in your program but you need to move it after a LogMsg command:
LogMode l
LogMsg mymsg
LogSave "[path]"
