Killed it several times. At least twice I was able to do this by
1. open workfile
2. object/var/econvar
3. specify and estimate including @trend
4. object/var - blewey
screen shot and file attached
blewey
blewey
- econ and history degrees.WF1
- (18.69 KiB) Downloaded 527 times
- Capture.PNG (85.7 KiB) Viewed 8688 times
Re: blewey
What is the build date? Is this 32-bit or 64-bit?
Re: blewey
February 26, 64-bit.
Re: blewey
What's the VAR spec?
Re: blewey
Default for variable EconBA and EconPhD with addition of exogenous @trend.
Re: blewey
You are having problem at estimation time? No problem here with "C @trend" and "@trend" alone.
Feb 26 64-bit
Feb 26 64-bit
Re: blewey
No. The problem happened on trying to open a new object after the estimation. I have no reason to believe the estimation was relevant.
Re: blewey
Do you get a "Delete Untitled VAR" prompt? What is your "Global Option/Environment/Allow only one untitled" setting? (Still can't replicate).
Re: blewey
No prompt, and I believe it happened before I closed the dialog.
