Introduce of object in program
Re: Introduce of object in program
Postby EViews Gareth » Thu Dec 28, 2017 9:26 am
You cannot, currently.
Postby EViews Gareth » Thu Dec 28, 2017 10:43 am
Because it isn't available as part of EViews.
Postby EViews Gareth » Thu Dec 28, 2017 11:39 am
Yes, EViews displays them, but they are not programmatically retrievable.
Postby EViews Gareth » Thu Dec 28, 2017 12:53 pm
EViews does not provide them. If you just need the table, I'm sure the original papers have them.
Postby startz » Thu Dec 28, 2017 2:55 pm
If Gareth tells you that some feature isn't built into EViews, you should probably believe him.
You can freeze a unit root view to get a table and then retrieve the critical values from the table, but it will probably take more work to figure out the location in the table than to look up the original paper.
Postby startz » Thu Dec 28, 2017 3:47 pm
Part of being a doctoral student is learning to find papers for yourself.
