Multiple Breakpoint Test (Bai Perron) for a replication of a paper
hello1994
Postby hello1994 » Wed Sep 27, 2017 11:34 am
I am attempting to replicate a paper by Jones and Olken (ungated link here https://economics.mit.edu/files/2911)
The paper identifies the structural breaks in countries growth rates and then looks at the factors associated with them. The structural breaks are identified from this equation:
I presume that first the structural breaks are identified, and then a regression is applied to the breaks in order to determine the associated factors.
I downloaded PWT 6.1, and know that the authors created a growth variable by taking the difference of annual the annual real GDP per capita (Laspeyres) (rgdpl in PWT6.1). I have imitated this, and know that my results are identical to the data set used by the original authors.
From the paper I know that Algeria has a structural (down)break in growth in the year 1981, and so I wanted to replicate this break first, and then proceed to expand the procedure to the whole data set, which is where I am struggling. I know that since the publication of the paper, EViews have installed a drop down click for the implementation of the multiple breakpoint test.
This is the data I am trying to identify the break from (only Algeria).
algeriatest2.xlsx
(129.79 KiB) Downloaded 308 times
I am estimating the equation:
growth c
and then am implementing the multiple breakpoint test with a trimming parameter of 10%; significance level of 10%; max break of 5; and the implementation method of sequential L+1 breaks vs.L) as per the paper, however I am not managing to find the structural break.
I know that I am probably making an extremely stupid mistake, any help would be invaluable!
Thanks!
hello1994
Re: Multiple Breakpoint Test (Bai Perron) for a replication of a paper
Postby hello1994 » Wed Sep 27, 2017 3:11 pm
The equation in the image is:
gt = aR + et where gt is the annual growth rate in purchasing-power-parity per-capita income, aR is the mean growth rate during regime R, and et is an error term drawn from a common distribution across regimes. As before, the data is taken from the Penn World Tables v6.1.
