I(1),I(0) and cointegration
hugo_eviews
Postby hugo_eviews » Thu Aug 31, 2017 8:36 am
I'm working with a model in which my dependent variable is I(1), two of my independent variables are I(1), but my third independent variable is I(0), in this case, if I find that the model as a cointegrating vector (using Phillips-Ouliaris), is it still correct to have a model which include a I(0) variable in a cointegration model (ECM or DOLS).
Thanks.
cgoes
Re: I(1),I(0) and cointegration
Postby cgoes » Tue Sep 05, 2017 3:12 pm
You can include it in the short run dynamics but no in the long run. So you exclude it from the equation in levels (which will estimate the error corretion term) and include it in the equation in differences. If it's a VAR, eviews allows you to impose restrictions in the VECM matrices.
dakila
Postby dakila » Tue Sep 05, 2017 6:13 pm
Try the ardl cointegration method (Pesaran 2001).
http://davegiles.blogspot.com/2013/06/a ... tests.html
EViews Mirza
Postby EViews Mirza » Tue Sep 05, 2017 8:20 pm
Actually, we have our own three part blog series on ARDL estimation, and your are strongly encouraged to read it.
http://blog.eviews.com/2017/04/autoregr ... l.html?m=1
http://blog.eviews.com/2017/05/autoregr ... 8.html?m=1
http://blog.eviews.com/2017/05/autoregr ... l.html?m=1
