error in Dumitrescu Hurlin test in Eviews 9?
Mateus
Postby Mateus » Mon Jul 10, 2017 1:58 am
This paper (https://www.unine.ch/files/live/sites/i ... P17-03.pdf) claims there is an error in Eviews 8 Dumitrescu Hurlin causality test code. Did you fix that for Eviews 9?
Re: error in Dumitrescu Hurlin test in Eviews 9?
Postby EViews Gareth » Mon Jul 10, 2017 9:26 am
We do not believe it is a bug in our code. We'll post more details soon.
Postby EViews Gareth » Mon Jul 10, 2017 2:23 pm
We'll go into even more detail at a later date, but to prove the results we're getting, here's some EViews code that computes the Wald statistics that they compute on page 8 of their paper.
wfopen .\data_demo.dta pagestruct id @date(t) 'compute granger causality using built in group g y x show g.cause(1, dh) 'loop through the cross-sections calculating Wald test for each individual !n = 10 matrix(!n,2) walds for !i=1 to !n smpl if @crossid=!i freeze(mode=overwrite, temp) g.cause(1) 'built in Granger Causality Test walds(!i,1) = temp(8,3) equation eq1.ls y c y(-1) x(-1) 'manually calculate using least squares freeze(mode=overwrite, temp) eq1.wald c(3)=0 walds(!i,2) = temp(7,2) next smpl @all 'display individual walds and their average show walds =@cmean(walds) 'means are equal (to a number of decimal places), and match the W-stat given in the built in procedure.
And here is some Stata code that produces the same things using Stata's built in Wald test and Granger Causality functions:
clear use "data_demo.dta", clear xtset id t xtgcause y x mat W = J(10,2,0) forvalues i = 1/10{ regress y L.y L.x if id==`i' test L.x matrix W[`i',1]=r(F) var y x if id==`i', lags(1/1) dfk small vargranger matrix a=r(gstats) matrix W[`i',2]=a[1,1] } matlist W
You can see that EViews produces exactly the same individual Wald statistics as Stata does, and that the EViews produced W statistic is the average of those individual Wald statistics.
data_demo.dta
(4.26 KiB) Downloaded 337 times
Mateus
Postby Mateus » Wed Jul 12, 2017 1:49 am
Thanks for that.
Did you check the Z statistics?
Postby EViews Gareth » Wed Jul 12, 2017 4:56 am
Yes, they are also correct.
Postby EViews Gareth » Wed Jul 12, 2017 6:18 am
Dumitrescu and Hurlin have now updated their code so that it matches EViews.
webers
Postby webers » Wed Jul 12, 2017 8:04 am
Dear Mateus, Dear Gareth,
We are the authors of the paper that raised the issue.
Following your previous posts, we have carefully investigated the difference between the results obtained with Eviews and our Stata command (xtgcause). As correctly indicated by M. Gareth, it turns out that the differences arise because of small sample adjustments, which were implemented in Eviews but not in xtgcause.
We therefore apologize for incorrectly judging Eviews’ command in our paper and for the trouble this may have caused.
We have already implemented a new version of the Stata command xtgcause that calculates the Wald and Z statistics with small sample adjustments. The output coincides with Eviews'. The new version of the command is attached to this post.
We are now updating the working paper and will replace the version currently online (dated 22Feb2017) as soon as possible.
We thank both of you for raising and discussing the issue.
Luciano Lopez and Sylvain Weber
xtgcause_2.0.zip
Package xtgcause, version 2.0
(4.39 KiB) Downloaded 337 times
