My daughter is starting usage of Eviews with version 6 standard edition.
Works fine until she uses control variables.
%x = 3 - seems to work fine
series test = !y - says !Y is not defined
series test = {!y} - says {!Y} is not defined
Does anyone know what is wrong ?
Thanks in advance
Paul
Control variables seem not to work
Re: Control variables seem not to work
sorry, i meant
!y = 3 - seems to work fine
Are you sure it isn't working?
The following code works fine for me:
create u 100
!y=3
series test = !y
series test2 = {!y}
Thanks for the response.
Copied and pasted your code. Same result : variable is not defined with or without brackets.
Could it be due to the fact that it is standard edition and not entreprise ?
Did you paste it into an EViews program, or did you paste it into the command window?
Control variables can only be used in an EViews program.
This is the case for both Standard and Enterprise editions.
Sorry and thanks a lot for the fast and useful response.
