Generate special series problem
karakilamaravilla
Postby karakilamaravilla » Tue Jun 13, 2017 12:54 pm
I need help creating a program that generates the following series:
-> My database is composed of 84 series of SKUs each containing 114 rows.
-> And 84 series of DemandaSKU that also contain 114 rows.
What I need is to generate a matrix (114,84) that in the fields has the following number:
The sum of how many rows in demandasku fit in stock?
Example: For row 1 of sku1 what is the number of rows of demandasku summed up to the value of row 1 sku1?
días piso reales.wf1
(219.87 KiB) Downloaded 311 times
EViews Matt
Re: Generate special series problem
Postby EViews Matt » Tue Jun 13, 2017 2:04 pm
Some clarification is needed. When you say "number of rows of demandasku summed up", do you mean initial rows, i.e., always start summing a column of demandasku from row 1?
karakilamaravilla
Postby karakilamaravilla » Tue Jun 13, 2017 2:41 pm
Dear,
As an example,
For SKU1 row 1: How many rows of DemandSKU1 (from row 1 to row) add at most the amount of row 1 of SKU1.
For SKU1 row 2: How many rows of DemandSKU1 (from row 2 through n) add at most the amount of row 2 of SKU1.
N depends on when the target is reached in the sum.
EViews Matt
Postby EViews Matt » Tue Jun 13, 2017 4:17 pm
I believe the following generates the first column of the results matrix you want (which I've called m). You can double check the results and generalize the code to all columns.
matrix(@obsrange, 1) m for !i = 1 to @obsrange %smpl = @str(!i) + " " + @str(@obsrange) series tmp = @cumsum(demandasku1, %smpl) <= @elem(sku1, !i) m(!i, 1) = @sum(tmp) next
karakilamaravilla
Postby karakilamaravilla » Tue Jun 13, 2017 7:08 pm
Dear Matt,
Your response was 100% satisfactory. How can I close the question, I am new here in this forum.
Thank you very much for your help.
EViews Matt
Postby EViews Matt » Wed Jun 14, 2017 8:43 am
I'm glad that worked for you. There's no procedure for closing threads in this forum, they remain open for future inquiries from anyone.
