calculate random effects
Gude
Postby Gude » Fri Jun 02, 2017 4:36 am
I am looking to guidance on how the random effects (cross-section, time/balanced, unbalanced) are calculated. I do not mean the model coefficients but the random effects avaiable via View -> Fixed/Random Effects.
I did not find anything in the user's guide nor in text books.
Re: calculate random effects
Postby EViews Glenn » Fri Jun 02, 2017 5:51 pm
It's based on the literature from the BLUP (Best Linear Unbiased Predictor) of the component effects. See, for example,
Goldberger (1962) or Baltagi (2001, Econometric Analysis of Panel Data).
sansa
Postby sansa » Sun Jun 04, 2017 10:52 am
Is there any legal version of this books online?
Gude
Postby Gude » Wed Jun 07, 2017 6:18 am
Thank you, Glenn.
Is there any guidance in simpler terms available?
Gude
Postby Gude » Fri Jun 09, 2017 7:43 am
Btw: The "Representations" (View -> Representations) seem a little odd:
Under "Substituted Coefficients", it is suggested to add the random effects to get the fitted values. But one gets the fitted values without adding the random effects. (Note: this is different in the fixed effect setting where one would indeed need to add the fixed effects)
Here is an example for the Grunfeld data in a one-way cross-section RE model:
Substituted Coefficients:
INV = -57.8460462503 + 0.109783684775*VALUE + 0.308110054652*CAPITAL + [CX=R]
And here for the one-way cross-section FE model:
INV = -59.0109113225 + 0.110124585857*VALUE + 0.310064218491*CAPITAL + [CX=F]
Postby EViews Glenn » Mon Jun 12, 2017 12:05 pm
The representations view is for forecasting. For fitted values, simply subtract the residuals from the observed.
