1/ with @wlookup @pagelist that i can rename all coefs series like this: d_{name of equation}_{name of page} (for @wlookup if i don't know what their names of equations), and the function @pageselect to switch between pages.
2/ equation eq02 have 4 coefs (@quarter=1 to @quarter=4).
Extract coefs form different objects, double seasonal
Re: Extract coefs form different objects, double seasonal
1)
2)
If Equation 2 only has 4 coefficients, why is this code referencing coefficient 4+!i where !i runs from 1 to 53?
%mypages = @pagelist
for %page {%mypages}
pageselect {%page}
rename myseries d_{name of equation}_{%page}
2)
for !i=1 to 53
smpl if @datepart(@date,"ww")=!i
series d_{%eq} = {%eq}.@coef(4+!i)
smpl @all
I have add 6 lines in the first of the code to rename the untitled pages to page_0!r, but it rename just the first page.
I get error message for my full program: 16 is not a valid index for vector-series-coefficient in "SERIES D_{%EQ} = EQ04.@COEF(4+12)".
- data+prg.zip
- (7.78 KiB) Downloaded 956 times
I don't think you have a grasp on what for loops do/are for. I all we can do is suggest you read up on for loops (in any programming language), and start experimenting / practicing until you get the hang of them.
Always try to picture in your mind exactly what the for loop is doing at each stage.
There are always keywords in your answers, it's pleasure to read them :) .
first, i agree that i have not use a methodology "loop for" in my code. i have problem to rename my pages Untitled page01 Untitled1 page02 Untitled2 page03.......( i can use this code it works, but i prefer to use @pagecount in the future if i need to rename multi pages)
second, i dont't now why i cannot extract all coefs, from my equations objects, manually it works.
could you look, if you can correct some mistakes.
for %1 %2 Untitled page01 Untitled1 page02 Untitled2 page03............etc
pagerename {%1} {%2}
nextcould you look, if you can correct some mistakes.
- prg_gdp_test44.prg
- (2.67 KiB) Downloaded 1036 times
1/I have use this code to rename all Untitled pages page_1, page_2,...: but i get error message.
2/I dont't now why i cannot extract all coefs, from my equations objects, manually it works. how can extract all the coefs?
Any help would be grateful.
for !r=1 to @pagecount
%page="page_"+@str(!r,"r02")
for %1 %2 {%mypages} {%page}
pagerename {%mypages} {%page}
nextAny help would be grateful.
How can rename my all pages untitled, by page_01 page_02....etc, and switch bitween pages and extract coefs from equations objects.
with my program and data.
- (2.67 KiB) Downloaded 735 times
- gdp_test3.wf1
- (76.55 KiB) Downloaded 733 times
Are there a solution for my loop for, could someone help me.
You need to figure this out for yourself.
Here's some code that will help you figure it out (or should!). Run it in a separate program on the same workfile.
table a 'this is a table object created to show what's going on inside loops
a(1,1) = "Iteration" 'add some column titles to the table
a(1,2) = "%page"
a(1,3) = "!r"
!row=2 'this is a counter keeping track of which row of the table we're on
setmaxerrs 100 'set the maximum number of errors before halting to something big, so we can see what's going on.
' rename untitled pages THIS IS YOUR CODE WITH SOME DEBUGGING LINES ADDED
a(!row,1) = !row-1 'set the first colum of the table equal to the iteration number (which since !row starts at 2, is just !row-1
a(!row,2) = %page 'set the second column equal to whatever %page is at the moment
a(!row,3) = !r 'set the third column equal to whatever !r is
!row = !row+1 'increase our counter by 1
pagerename {%page} page_0!r
show a
Thanks for this few lines, it was help me to understand the logic of loop for, now i can rename all pages with loop, but i get error message. i will look if i can solve this....
i hope
