Stepwise Regression White errors
invest2risk
Postby invest2risk » Mon Dec 28, 2009 5:36 am
Hi!
I'm trying to find a model using stepwise regression and was wondering if it is possible to use white errors within the algorithm.
As I read in a different thread (http://forums.eviews.com/viewtopic.php? ... hite#p4666) white errors are not used for F-statistic, which I suppose is the selection criterion for the algorithm?
Since I am a newbie at EViews I would appreciate if you could give hints as precise as a newbie unfortunately needs them :)
Regards,
Georg
Re: Stepwise Regression White errors
Postby EViews Gareth » Mon Dec 28, 2009 9:11 am
The built-in stepwise regression routines do not support White errors. You can always write your own in the EViews programming language.
I should point out, of course, that it really depends upon how you want to do the model selection. Any of the methods that are R-Squared based will not be affected by the standard error choice.
