I wanted to know is there any trick to control the variables to be included in the estimation using programming.
For example, for variables y and x. If I want to include only y(-2) and x(-2) in the estimating equation, i.e. y c y(-2) x(-2).
Or if I want to include y(-3) x(-2) into the equation: y c y(-3) x(-2).
Is there any trick in writing a program so that I can control which variables or which lags only included into the estimation?
Thanks.
Sam
Control variables to be included in estimation via programming.
Re: Control variables to be included in estimation via programming.
I don't understand this question.
If you want y(-2) and x(-2) as regressors, then use them.
Sorry for my unclear question. Let's consider the case:
By writing a program code, I write out the general equation in my program, e.g. equation.ls y c y(-1) y(-2) y(-3) y(-4) x(-1) x(-2) x(-3) x(-4)
Next, I wish to use the general equation to run several estimation by controlling the variables or lag length. For example, for a sample sets, we know that only y(-2) and x(-3) are found to be significant. Thus, I wish to estimate the equation by including only the variables y(-2) and x(-3).
I don't wish to specify several possible cases of the equations like specifying
if lagy = 1 then
equation.ls y c y(-1) x(-1) x(-2) x(-3) x(-4)
else if lagy = 2 then
equation.ls y c y(-1) y(-2) x(-1) x(-2) x(-3) x(-4)
and etc.
I don't wish to writing the program code as above as it would be very tedious and complicated for my specific case. I wish to only using the general equation and (or) use the program argument to manipulate the estimating equation.
Therefore, my question is is there any tricks that I can control the including variables for the estimation by using the general equation?
Thanks!
if lagy = 1 then
and etc.
Thanks!
It still isn't very clear - How will the automated process know that after estimating:
The next estimation is just:
Perhaps if you can explain the logic behind what you are doing, we can explain how to do it.
But, as an aside, you can specify an equation as:
y c y(-2) x(-3)
y c y(-1 to !lagy)
Hi, thanks for your patient on my problem.
Actually I am writing a bootstrap method program. Before going to the bootstrap step, I need to estimate an equation and save the coefficients of the estimating variables.
My problem here is that, I have no idea how to come out a program code that can control which lag of the variables to be included into the equation. If I don't use the program, I know I can use the default software by simply clicking on the button 'quick' then 'estimate equation' and then just simply declare the variables to be estimated, eg. y c y(-2) x(-3). But in programming, I know I couldn't.
As your suggestion, I can come out the equation as:
y c y(-1 to !lagy) x(-1 to !lagx)
and define the numbers for !lagy and !lagx.
However, this will include those lags between the range into the equation. Example, if I declare !lagy = 2 and !lagx = 3, then the equation will be estimated as y c y(-1) y(-2) x(-1) x(-2) x(-3). Here I wish to include those significant lag of the variables into the equation, for example, only y(-2) and x(-3): y c y(-2) x(-3).
Is there any tricks or ways for me to estimating the specific equation flexibly?
Your helps are well-appreciated.
Since there is no logic to the specification, there is not way to automate it.
