Panel cointegration
gislaine_mq
Panel cointegration
Postby gislaine_mq » Mon Jan 09, 2017 10:28 am
Hello
I'm estimating a cointegrated panel model. I did the unit root tests, cointegration tests and estimation of the DOLS and FMOLS models. My question is how to know the level of significance of the statistics found? At the levels of 1%, 5% and 10%, usually presented by asterisks, respectively, *, **, ***. I can not see in the Eviews results.
thanks
Krille
Re: Panel cointegration
Postby Krille » Sat Jan 14, 2017 3:45 pm
Can't you use the t-stats ans p-values?
/Krille
gislaine_mq
Postby gislaine_mq » Sun Jan 15, 2017 10:10 am
Yes, but I was in doubt about the level of significance.
Gislaine
Krille
Postby Krille » Sun Jan 15, 2017 12:40 pm
Ok, I see.
If your p-value is lower than 0.10 then you have one-star significance, lower than 0.05 two-star, and lower than 0.01 three-star-significance.
Hope this can help.
/Krille
