I have a database of carriers, airport and others variables as degree of an airport from 1999Q1 to 2013Q4.
What I do is estimate an AR(1) model for degree of the carrier "AA" on the airport "MIA" from 1999Q1 to 2010Q4
The equation is named eq_ar in my workfile attached.
When I try to dynamically forecast from 2011Q1 to 2013Q4 in order to compare the forecasting output with real values,it says " Unable to compute due to missing datas".
I have seen that some posts deal with this error but I did not really undestand what to do.
Thank you for your help
AR(1) forecasting
AR(1) forecasting
- airport_data.wf1
- (1.93 MiB) Downloaded 231 times
Re: AR(1) forecasting
Is your version of EViews up-to-date?
What exactly did you do? (Seemed to work fine for me)
Thanks for you quick replies.
I have selected the equation "eq_ar" which corresponds to an AR(1) for estimation until 2010 Q4 and selected "Forecast" and just changing the date of the sample as following :
2011q1 2013q4 if carrier="AA" and airport="MIA".
And then it says the error message "unable to compute due tomissing datas" but it creates me the variable degreef whatever.
So i checked the graph I wanted, and it is definitely not what I should have (see the attachement ...)
- image.jpg (41.43 KiB) Viewed 7079 times
Check you version is up to date.
I am using eviews 9 and I cannot update my version because it is a license for university ...
When I try to update it says :
" This feature has been disabled by your administrator "
I finally managed to update eviews to the latest version.
I got a new error message, you can see it on the image.
I do not get it insofar as my workfile range is until 2013Q4 and I should not be outside my workfile range..
- 2.png (96.62 KiB) Viewed 7067 times
- 1.png (102.7 KiB) Viewed 7067 times
If you click ok on the error, does the forecast happen?
Yes, the forecast happens and I got this
(The forecasted value is a constant which corresponds to the constant of the ar(1) model)
- 3.png (88.74 KiB) Viewed 7053 times
Seems like it is working then.
