Matching a date with a series observation
ashtongate
Postby ashtongate » Mon Nov 23, 2009 8:20 am
Anyone know how to match a series observation to a date? I know about @dtoo and @otod, but I am thinking more of identifying the date for which a series reached it maximum value; i.e. I do not know the observation number, just the criteris (that it is the max),
Cheers!
Re: Matching a date with a series observation
Postby EViews Gareth » Mon Nov 23, 2009 8:59 am
=@otod(@imax(x))
where x is the name of your series.
ashtongate
Postby ashtongate » Mon Nov 23, 2009 9:12 am
Great, thanks!
atoch
Contact:
Postby atoch » Thu Dec 03, 2009 10:20 am
Bonjour,
I'm trying to use the @otod() function.
Documentation says it returns a string but when I try to store the output of @otod() into an object of type alpha, I receive an error massage saying that @OTOD is not a Genr or series expression function.
alpha mytext mytext = @otod(@imax(FRA_CG_ADBQ))
Where FRA_CG_ADBQ is a quarterly time series with a sample running from 1950q1 to 2009q2.
I've tried simplier versions of the above code like :
%1 = @otod(5)
I don't receive the error message but I can't access the content of the temporary variable %1 so it doesn't help.
Arnaud Atoch
Postby EViews Gareth » Thu Dec 03, 2009 11:00 am
alpha mytext %s = @otod(5) mytext = %s
atoch
Contact:
Postby atoch » Thu Dec 03, 2009 12:26 pm
Thanks.
When running your above code the following error is produced :
%s is not defined
Both with Eviews6 and Eviews7 beta.
Arnaud Atoch
Postby EViews Gareth » Thu Jan 21, 2010 10:38 am
Sounds like you're running the code from the command line, rather than from within an EViews program. You'll have to run it in an EViews program.
If you want to use it from the command line, you could do:
alpha mytext string s = @otod(5) mytext = s
