We have recently been exploring MiDaS in EViews, it is a really great feature. Also, the MiDaS webinar was superb.
However, I have a minor problem with the Almon/PDL weighting in the MiDaS estimation. The issue is described in the attached PDF.
Also, when determining the degree of the Almon polynomial, I miss an estimated parameter. Suppose that I choose polynomial degree 3. Then I would expect to get 4 estimated parameters (the a_i:s) for the polynomial: a_0+a_1*X+a_2*X^2+a_3*X^3. But only three estimated parameters are presented in the output. I suspect that a second degree polynomial is estimated when setting polynomial degree to 3: a_0+a_1*X+a_2*X^2. Is this so or is it a restricted (a_0=0) third degree polynomial (a_1*X+a_2*X^2+a_3*X^3) that is estimated?
Best,
Kristian
Almon/PDL in MiDaS
Almon/PDL in MiDaS
- AlmonLagsEViews.pdf
- (84.61 KiB) Downloaded 558 times
Re: Almon/PDL in MiDaS
Here's an EViews program that manually computes an example MIDAS model, and shows the weighting calculations:
!xlags = 4
!ylags=1
!horizon=2
!polyorder = 3 ' matlab order +1
wfopen(wf=midas, page=quarterly) .\mydata.xlsx range="Sheet1"
pageload(page=monthly) .\mydata.xlsx range="Sheet2"
series x1 = dlog(value(-!horizon))*100
for !i=2 to !xlags
series x!i = x1(-!i+1)
for !i=1 to !xlags
series z!i=x!i(-2)
pageselect quarterly
series y = dlog(value)*100
smpl 1985 2009/1/1
for !i=1 to !xlags
copy(c=l) monthly\z!i x!i
for !i=1 to !polyorder
series z!i=0
for !i=1 to !xlags
for !j=1 to !polyorder
z!j = z!j + !i^(!j-1)*x!i
group xlags z*
group ylags
for !i=1 to !ylags
ylags.add y(-!i)
equation eq2.ls y c xlags ylags
show eq2
equation eq1.midas(freq=first) y c y(-1) @ monthly\x1
show eq1
- mydata.xlsx
- (47.65 KiB) Downloaded 445 times
It is exectly this I am after.
Estimations in EViews and the MiDaS toolbox for Matlab use the weighting
for !i=1 to !xlags
In the documentation for the MiDaS Matlab toolbox (see equation 2.10 in the documentation for version 2.1 as of August 3, 2016), in the documentation for EViews 9.5 (Equation 28.6) and in Intriligator (1978) Econometric models, techniques, and applications, page 183, equation 6.7.28, the weighting described for the Almon/PDL case is
for !i=1 to !xlags
z!j = z!j + (!i-1)^(!j-1)*x!i
This might of course be a minor difference (although the curvature of the estimated parameters seems to be affected), but if I understand you correctly it is the documentation that is the candidate to be changed and not the estimation routine?
for !i=1 to !xlags
for !i=1 to !xlags
