In a program I regularly run there are a quite a big number of time series (around 3500) stored from one workfile into two databases (~1.5MB and ~2.5MB), all located on a network drive. Over the recent months the performance of the storing process has suffered a lot (I just did a test from an HPC server and it took 13 minutes), and our IT people told us that this was due to high activity on the network. While they said they are looking into it, this might take a while until this gets better. So I was wondering if there is a better alternative to the store command. I don't have an alternative to doing this data management on a network drive as the series need to be accessible to a number of colleagues.
For a subset of the data I already tested the copy command and it seemed a lot faster. Is there a difference in how these two commands work? Or should the two commands be equally fast and this is only due to the fact that the copy operation kind of works in "quiet mode" while for store you see the series being copied? Is there any risk of changing my code to use the copy command? Are there similar performance differences between a fetch and a copy from database to workfile? Fetch works much faster than store, but still it takes a while when the network drive is busy...
I work in Eviews 9.5 (but I also had this performance issue in Eviews 8 already).
Basically what is currently used is the store command with a wildcard search.
%PEVDB refers to the folder path of the database location and %WV is the first part of the filename.
PAGESELECT Q
%filename = %PEVDB+%WV+"Q"
STORE(D=%filename) {%R}_{%F}_Q_*
PAGESELECT A
%filename = %PEVDB+%WV+"A"
STORE(D=%filename) {%R}_{%F}_A_*
Any ideas?
PAGESELECT Q
copy {%R}_{%F}_Q_* {%WV}Q::
PAGESELECT A
copy {%R}_{%F}_A_* {%WV}A::
Many thanks in advance for your help.
Best regards,
Alex
