Hi everybody,
i am trying to test the cointegration between 15 series with the johansen test but eviews said "Warning: Rank test critical values not available for more than 12 endogenous series"..
how could i implement the johansen test with 15 series or more?
thank you.
johansen test for cointegration
Re: johansen test for cointegration
do all of the series you want to make cointegreation test have the same integreation order?
Hello ermutuxia,
I don’t know if you are familiar with cointegration analysis within the Johansen framework but how do we proceed in the case where there is a mix of I(0) and I(1) variables?
Regards
Regards
Don't they all have to integrated of the same order to have cointegration? I think so.
You can proceed to cointegration even if there is a mix of I(0) and I(1) variables! Each stationary variable will reveal itself as a cointegrating vector.
Regads
Regads
