Specifying a model using a wildcard
neilblake
Postby neilblake » Thu Oct 29, 2009 10:36 am
Is there an easy way to create a model which contains every equation in a workfile or, alternatively, a model that contains every equation with a name that starts with the same letter or string of letters?
Re: Specifying a model using a wildcard
Postby EViews Gareth » Thu Oct 29, 2009 1:25 pm
In EViews 7 you could create a wordlist (using wlookup) containing every equation in your workfile, then loop through those equations adding them to the model one by one.
In EViews 6 I cannot think of way to do it.
neilblake
Postby neilblake » Wed Nov 04, 2009 11:51 am
Is there any documentation on how to use WLOOKUP in Eviews 7?
Postby EViews Gareth » Wed Nov 04, 2009 11:22 pm
Yep. If you open up the Beta documentation PDF from the help menu and then do a search for wlookup, you should find it.
Return to “Models”
