Update default directory
When I do a SaveAs in a multi-page workfile (probably not relevant), the SaveAs dialog opens to This PC rather than the default directory. I am running WIndows 10 (probably is relevant).
Re: Update default directory
If the workfile already exists on disk and you are attempting to 'save as', the 'save as' dialog will open to the location of the workfile.
If you choose 'save as' from an untitled workfile, the dialog opens to your default directory.
Are you seeing different behavior?
That may be what was going on. If I can document a different behavior I'll repost.
