How to restrict a variable to its initial observation
Tuinsmurf
Postby Tuinsmurf » Thu Jun 23, 2016 3:57 am
I am running an economic growth regression for 8 countries between 1984-2008. One of the first independent variables is the initial GDP per capita for each country.
How would I restrict my variable to the initial observation for each country in a regression in EViews? I thought about creating another variable in excel, which only shows the initial observation for each country, but I am not sure if importing this into EViews will yield the same results.
Thank you for the help!
Tuinsmurf
Re: How to restrict a variable to its initial observation
Postby EViews Gareth » Thu Jun 23, 2016 5:50 am
You'll end up with a variable that is constant for each cross-section. That's just a fixed effect.
Postby startz » Thu Jun 23, 2016 8:59 am
Not necessarily. Including the initial observation isn't the same as including a fixed effect because all countries are constrained to have the same coefficient.
Postby EViews Glenn » Thu Jun 23, 2016 10:47 am
Assuming you are panel structured
series z=@firstsby(y, @crossid)
