frequency not working
hello, ı am trying to convert quarterly gdp to monthly gdp, I looked for the problem on the forum (http://www.eviews.com/help/helpintro.ht ... 0.035.html) but my problem is different than those one. In this link, http://forums.eviews.com/viewtopic.php?f=7&t=3799 it is described how to do bıt in my workpage, although I have original quarterly data and a new monthly page, I still cant convert it, I dont have "frequensy conversion odtion" part in the "paste special" window, only "match merge option" part is available. Please help me, althoug I tried again and again, I still cant get result. If 2005Q4 is 12, it gives me 2005m10, 2005m11, 2005m12 the same value, 12 again.:(((
Re: frequency not working
ths is the file I have had. it shows the same valu for 3 months while converting from quarter
When I change the number format, comma and point problem, it again doesn't show "specified in series" part, only "specified as source" part and at the end it gives the same 3 numbers for three months again.
this is my result file:((( please help. I have been doing for hours but nothing changes..
- gdp result.WF1
- (19.95 KiB) Downloaded 397 times
Hi.
I'm afraid I am having trouble figuring out what you are describing. What exactly is the issue?
When I open up your file, I can see GDP has been converted from quarterly to monthly, seemingly just fine.
Hi.
hi, it seems as if it converted the data, it makes 12 cells for a year, ok, but in three cells of the year, the same data appears. I mean, if quarterly data of 2015 Q1 is 10, it wrotes 10-10-10 for the 1st 2nd and third month of 2015. ıt only copies the same value to three cells:(((
