Eigenvalue/vectors order
xprimexinverse
Contact:
Postby xprimexinverse » Sun May 08, 2016 7:29 am
I am using the @eigenvalues() and @eigenvectors() functions and have a question regarding how their outputs are ordered. I am using EViews version 9.5.
Quoting the EViews manpages for @eigenvectors,
"The eigenvalues are arranged in ascending order, and the columns of the eigenvector matrix correspond to the sorted eigenvalues."
I would like, instead, to have the eigenvalues arranged in descending order by absolute value, and the columns of the eigenvector matrix correspond to the newly sorted eigenvalues.
Could a demonstration please be provided? Fundamentally, it's a problem about rearranging the columns of a matrix according to an indexing scheme.
For example, suppose I have a symmetric matrix called sym1.
' Solve eigenvalue problem vector evals = @eigenvalues(sym1) matrix evecs = @eigenvectors(sym1) ' Sort eigenvalues in descending order by absolute value vector evals2 = @sort(@abs(evals),"d") ' Sort columns of the eigenvector matrix to correspond to the newly order eigenvalues ' Insert code here
My attempt is as follows.
vector idx = @ranks(evals2, "a", "i") matrix evecs2 = @rapplyranks(evecs,idx)
This nearly completes the task, but I also need to take into account any conversions made by the @asb() function.
For example, if one of the eigenvalues was negative, the @abs() function would, in effect, multiply this by negative one. I require the same transformation to be applied to the corresponding columns of the eigenvector matrix. How do I achieve this?
Graeme
-- Ah! I think I have it, I can just use something like @egt(evals,@zeros(@rows(evals))) and go from there. But, does seem like overkill!?
xprimexinverse
Contact:
Re: Eigenvalue/vectors order
Postby xprimexinverse » Sun May 08, 2016 8:38 am
I'll answer this myself since I think I figured it out; however, suggestions are welcome.
By the way, the context of this is in programming Johansen's estimator.
Here's my proposed solution.
' Solve eigenvalue problem vector evals = @eigenvalues(sym1) matrix evecs = @eigenvectors(sym1) ' Create "multiplication" matrix vector pos = @sort(@egt(evals,@zeros(@rows(evals))),"d") for !i = 1 to @rows(pos) if pos(!i) = 0 then pos(!i) = -1 endif next matrix mult = @makediagonal(pos) ' Sort eigenvalues in descending order by absolute value vector evals2 = @sort(@abs(evals),"d") ' Sort columns of the eigenvector matrix to correspond to the newly order eigenvalues vector idx = @ranks(evals2, "a", "i") matrix evecs2 = @rapplyranks(evecs,idx) ' Use "multiplication" matrix to perform the -1 transformations matrix evecs3 = @transpose(mult * @transpose(evecs2))
Graeme
