hello! i'm using Eviews 8.0 (awaiting the wheels of bureaucracy at colorado state univ to turn enough to let me upgrade to 9.5).
i've run a pair of models using two-stage and now must check for endogeneity between the DVs (they also are IVs in the respective models).
the online help manual says this: The Instrument Summary view may be found under View/IV Diagnostics & Tests/Instrument Summary, but i don't find such an option when i click on View. can you suggest a direction? thanks so much!
eljay
basic endogeneity test question
Re: basic endogeneity test question
Are you estimating an equation or a system?
two equations in sequence
Panel data?
They're not available for panel estimation.
does 9.5 have such capability? thank you.
Not built in
