Zivot-Andrews Unit Root Test
For posting your own programs to share with others
trubador
Did you use forum search?
Postby trubador » Mon Oct 05, 2009 6:59 am
Attached is a subroutine to carry out Zivot-Andrews procedure for testing unit root in the case of a single break in the series (i.e. level, trend or both). Please feel free the optimize the code further.
'Zivot-Andrews Unit Root Test 'Reference: Zivot, E. and Andrews, D. W. K. (1992), “Further Evidence on the Great Crash, the Oil-Price Shock, and the Unit-Root Hypothesis”, Journal of Business & Economic Statistics, Vol. 10, No. 3, pp. 251-270. call zivot(y,"C",4) ' ---------------------------------------------------------------------------------------------------- ' Arguments '----------------------------------------------------------------------------------------------------- 'series Y ' dependent variable 'scalar Maxlag ' Maximum number of lags for unit root testing 'string %Model ' Location of the break ("A" = Intercept, "B" = Trend, "C" = Both) ' ---------------------------------------------------------------------------------------------------- subroutine zivot(series y,string %Model,scalar maxlag) !trim = 0.15 'Trimming parameter series DY = D(Y) !nobs = @obs(y)-maxlag-1 smpl @first+maxlag+1 @last equation temp.ls dy c @trend y(-1) !aic0 = log(temp.@ssr/!nobs)+2*(temp.@ncoef/!nobs) !bic0 = log(temp.@ssr/!nobs)+ log(!nobs)*(temp.@ncoef/!nobs) !min_aic = !aic0 for !lag=maxlag to 1 step -1 equation temp.ls dy y(-1) c @trend dy(-1 to -!lag) !aic = log(temp.@ssr/!nobs)+2*(temp.@ncoef/!nobs) !bic = log(temp.@ssr/!nobs)+log(!nobs)*(temp.@ncoef/!nobs) if !aic < !min_aic then !min_aic = !aic !best_lag = !lag else if !min_aic = !aic0 then !best_lag =0 endif endif next smpl @all !znobs = @obs(y) - !best_lag !lower = 1+!best_lag+@round(!znobs*!trim) !upper = @obs(y)-@round(!znobs*!trim) vector(!upper-!lower+1) results smpl @first + !best_lag @last for !i = !lower to !upper if !best_lag=0 and %Model = "A" then equation temp.ls DY Y(-1) C @trend (@trend>!i-2) else if !best_lag=0 and %Model = "B" then equation temp.ls DY Y(-1) C @trend (@trend>!i-2)*(@trend-!i+2) else if !best_lag=0 and %Model = "C" then equation temp.ls DY Y(-1) C @trend (@trend>!i-2) (@trend>!i-2)*(@trend-!i+2) else if !best_lag>0 and %Model = "A" then equation temp.ls DY Y(-1) C @trend (@trend>!i-2) DY(-1 to -!best_lag) else if !best_lag>0 and %Model = "B" then equation temp.ls DY Y(-1) C @trend (@trend>!i-2)*(@trend-!i+2) DY(-1 to -!best_lag) else if !best_lag>0 and %Model = "C" then equation temp.ls DY Y(-1) C @trend (@trend>!i-2) (@trend>!i-2)*(@trend-!i+2) DY(-1 to -!best_lag) endif endif endif endif endif endif results(!i-!lower+1) = temp.@tstats(1) next vector t_min =@cmin(results) !t_min = t_min(1) vector break = @cimin(results)+!lower-1 !break = break(1) series DT = (@trend>!break-2)*(@trend-!break+2) if %Model = "A" or %Model="C" then series DU = @trend> !break-2 endif if !best_lag=0 and %Model="A" then equation ZA.ls DY Y(-1) C @trend DU 'Selected equation else if !best_lag=0 and %Model="B" then equation ZA.ls DY Y(-1) C @trend DT 'Selected equation else if !best_lag=0 and %Model="C" then equation ZA.ls DY Y(-1) C @trend DU DT 'Selected equation else if !best_lag>0 and %Model = "A" then equation ZA.ls DY Y(-1) C @trend DU DY(-1 to -!best_lag) 'Selected equation else if !best_lag>0 and %Model = "B" then equation ZA.ls DY Y(-1) C @trend DT DY(-1 to -!best_lag) 'Selected equation else if !best_lag>0 and %Model = "C" then equation ZA.ls DY Y(-1) C @trend DU DT DY(-1 to -!best_lag) 'Selected equation endif endif endif endif endif endif table(6,2) ZAZ ZAZ(1,1) = "Variable(s)" ZAZ(3,1) = "t-stat(s)" ZAZ(4,1) = "Lag(s)" ZAZ(5,1) = "Break" ZAZ(6,1) = "DU1 p-value" ZAZ(1,2) = y.@name ZAZ(3,2) = !t_min ZAZ(4,2) = !best_lag if @datestr(@now,"F") = "?" then ZAZ(5,2) = !break else ZAZ(5,2) = @otod(!break) endif ZAZ(6,2) = @tdist(za.@tstat(4),za.@regobs-za.@ncoef) setline(ZAZ, 2) show ZAZ smpl @all delete temp break results t_min endsub
hetero
Re: Zivot-Andrews Unit Root Test
Postby hetero » Tue Oct 06, 2009 2:49 am
I have compared the results delivered from the above E-views code with those delivered from the corresponding RATS code. They are identical. This is a perfect piece of work. We are grateful Trubador!!
For users convenience the asymptotic critical values are provided below:
model Α model Β model C
1% -5.34 -4.93 -5.57
5% -4.80 -4.42 -5.08
10% -4.58 -4.11 -4.82
Regards
adwy
Postby adwy » Wed Oct 07, 2009 12:51 am
Thank you so much Trubador! You are so nice. Cheers.
hetero
Postby hetero » Tue Oct 20, 2009 3:13 am
Dear Trubador,
It would be of great pleasure if a Monte Carlo simulation was also applied to calculate the exact critical values according to the sample size used each time. Is it hard to program something like that? Once again thank you for your contribution!
Regards
trubador
Postby trubador » Thu Oct 22, 2009 10:18 am
Yes, you are right. This will also complete program and fully replicate the original study.
It is not that much a difficult task, but definitely requires a different way of programming.
hetero
Postby hetero » Fri Oct 23, 2009 3:43 am
Hi Trubador,
Please forgive me for the indiscreet question but is there any intension to complete the program by incorporating Monte Carlo simulations?
Kind Regards
trubador
Postby trubador » Sat Oct 24, 2009 7:12 am
It is in my mind, but I do not think I can spare the time in the foreseeable future.
nat
Postby nat » Wed Nov 04, 2009 11:15 am
I have a question. When I tried to run this programm in E-views the Error message appeared and it said that @cmin command from
"vector t_min =@cmin(results)
!t_min = t_min(1)
!break = break(1)"
is illigal or allready used. Could you tell me what can be wrong?
Thank you.
trubador
Postby trubador » Wed Nov 04, 2009 12:05 pm
You are probably using an earlier version of EViews. Those functions were introduced as of version 6 and are not supported in earlier versions of EViews. Please try the (slightly) modified code below:
'Zivot-Andrews Unit Root Test 'Reference: Zivot, E. and Andrews, D. W. K. (1992), “Further Evidence on the Great Crash, the Oil-Price Shock, and the Unit-Root Hypothesis”, Journal of Business & Economic Statistics, Vol. 10, No. 3, pp. 251-270. call zivot(y,"C",4) ' ---------------------------------------------------------------------------------------------------- ' Arguments '----------------------------------------------------------------------------------------------------- 'series Y ' dependent variable 'scalar Maxlag ' Maximum number of lags for unit root testing 'string %Model ' Location of the break ("A" = Intercept, "B" = Trend, "C" = Both) ' ---------------------------------------------------------------------------------------------------- subroutine zivot(series y,string %Model,scalar maxlag) !trim = 0.15 'Trimming parameter series DY = D(Y) !nobs = @obs(y)-maxlag-1 smpl @first+maxlag+1 @last equation temp.ls dy c @trend y(-1) !aic0 = log(temp.@ssr/!nobs)+2*(temp.@ncoef/!nobs) !bic0 = log(temp.@ssr/!nobs)+ log(!nobs)*(temp.@ncoef/!nobs) !min_aic = !aic0 for !lag=maxlag to 1 step -1 equation temp.ls dy y(-1) c @trend dy(-1 to -!lag) !aic = log(temp.@ssr/!nobs)+2*(temp.@ncoef/!nobs) !bic = log(temp.@ssr/!nobs)+log(!nobs)*(temp.@ncoef/!nobs) if !aic < !min_aic then !min_aic = !aic !best_lag = !lag else if !min_aic = !aic0 then !best_lag =0 endif endif next smpl @all !znobs = @obs(y) - !best_lag !lower = 1+!best_lag+@round(!znobs*!trim) !upper = @obs(y)-@round(!znobs*!trim) vector(!upper-!lower+1) results smpl @first + !best_lag @last for !i = !lower to !upper if !best_lag=0 and %Model = "A" then equation temp.ls DY Y(-1) C @trend (@trend>!i-2) else if !best_lag=0 and %Model = "B" then equation temp.ls DY Y(-1) C @trend (@trend>!i-2)*(@trend-!i+2) else if !best_lag=0 and %Model = "C" then equation temp.ls DY Y(-1) C @trend (@trend>!i-2) (@trend>!i-2)*(@trend-!i+2) else if !best_lag>0 and %Model = "A" then equation temp.ls DY Y(-1) C @trend (@trend>!i-2) DY(-1 to -!best_lag) else if !best_lag>0 and %Model = "B" then equation temp.ls DY Y(-1) C @trend (@trend>!i-2)*(@trend-!i+2) DY(-1 to -!best_lag) else if !best_lag>0 and %Model = "C" then equation temp.ls DY Y(-1) C @trend (@trend>!i-2) (@trend>!i-2)*(@trend-!i+2) DY(-1 to -!best_lag) endif endif endif endif endif endif results(!i-!lower+1) = temp.@tstats(1) next vector t_min =@min(results) !t_min = t_min(1) vector break !i =1 while !i<=!upper-!lower+1 if results(!i) = @min(results) then break = !i+!lower-1 endif !i = !i+1 wend !break = break(1) series DT = (@trend>!break-2)*(@trend-!break+2) if %Model = "A" or %Model="C" then series DU = @trend> !break-2 endif if !best_lag=0 and %Model="A" then equation ZA.ls DY Y(-1) C @trend DU 'Selected equation else if !best_lag=0 and %Model="B" then equation ZA.ls DY Y(-1) C @trend DT 'Selected equation else if !best_lag=0 and %Model="C" then equation ZA.ls DY Y(-1) C @trend DU DT 'Selected equation else if !best_lag>0 and %Model = "A" then equation ZA.ls DY Y(-1) C @trend DU DY(-1 to -!best_lag) 'Selected equation else if !best_lag>0 and %Model = "B" then equation ZA.ls DY Y(-1) C @trend DT DY(-1 to -!best_lag) 'Selected equation else if !best_lag>0 and %Model = "C" then equation ZA.ls DY Y(-1) C @trend DU DT DY(-1 to -!best_lag) 'Selected equation endif endif endif endif endif endif table(6,2) ZAZ ZAZ(1,1) = "Variable(s)" ZAZ(3,1) = "t-stat(s)" ZAZ(4,1) = "Lag(s)" ZAZ(5,1) = "Break" ZAZ(6,1) = "DU1 p-value" ZAZ(1,2) = y.@name ZAZ(3,2) = !t_min ZAZ(4,2) = !best_lag ZAZ(5,2) = @otod(!break) ZAZ(6,2) = @tdist(za.@tstat(4),za.@regobs-za.@ncoef) setline(ZAZ, 2) show ZAZ smpl @all delete temp break results t_min endsub
nat
Postby nat » Wed Nov 04, 2009 12:18 pm
Thank you Trubador, youou are right, I am using 4.0 version. But the lighter version which you sent has some problems as well. It does not recognize
@datestr in
"if @datestr(@now,"F") = "?" then".
So I will try to find upper version.
Thank you Trubador.
nat
Postby nat » Wed Nov 04, 2009 12:25 pm
I am sorry version which I am using is 4.1, not 4.0. After showing an error message (which I mentioned above), I noticed that two equations Temp and ZA were created in my workfile, and ZaZ table. Is it what I have to have after this programm? In this case it seems that no problem?
trubador
Postby trubador » Wed Nov 04, 2009 12:41 pm
Since you are using an older version, you may not always be able to run codes written in newer versions. In this case, however, I do not think that you are facing a serious problem. You can remove the following part altogether:
and replace it with the following single line, since @otod provides a more general use:
I have already edited my previous post in the same way...
nat
Postby nat » Thu Nov 05, 2009 5:02 am
Dear Trubador,
Thank you very much! It worked!
Thanks again!
donihue
Postby donihue » Sat Nov 21, 2009 5:27 am
Following up on this very helpful exchange:
Would you have written a code for the Clemente-Montanes-Reyes unit root test, which also alows for two structural breaks (it is implemented in Stata as "clemao" or "clemio", depending on form)?
Many thanks
Regards
Donihue
trubador
Postby trubador » Wed Nov 25, 2009 11:27 am
Many thanks
Regards
Donihue
As you might have noticed, we tried to write a code for Lumsdaine-Papell unit root test. However, we did not have enough time to finish it. I cannot promise anytime soon, but I will complete that work as soon as I have spare time.
Actually, I am not an expert on unit root testing and do not follow the recent developments in the literature very closely. I do know that there are lots of variants of unit root tests, each of which serves to a different purpose. I think it would be useful and helpful to implement unit root tests in EViews that are commonly used or proved to be robust in practice.
Return to “Program Repository”
