How to see Model Coefficients
kszynkar
Postby kszynkar » Fri Mar 11, 2016 8:22 am
I have a model. One of the sets of equations is:
dlogcns1_sa = c(11) + c(12) * @movav(dlogcns1_sa(-1) , 12) + c(13) * dlogcns1_sa(-12) + c(14) * (dlogcns1_sa(-1) - c(11) + c(12) * @movav(dlogcns1_sa(-2) , 12) + c(13) * dlogcns1_sa(-13))
How do I see the coefficients generated by the least squares regression?
I clicked the "solve" button, then "view/equations", double clicked on it, but I don't see any coefficients.
kszynkar
Re: How to see Model Coefficients
Postby kszynkar » Fri Mar 11, 2016 8:32 am
Also, if I ran this for
smpl @first 2013m12
How would I forecast each number in the series to the last (unknown) one?
Postby EViews Gareth » Fri Mar 11, 2016 8:48 am
The model does not perform any least squares regressions. If you specify the model in terms of c(11) etc..., the model will use whatever values are contained in the C vector on solve. It will not estimate those values.
I don't understand your second question.
kszynkar
Postby kszynkar » Mon Mar 14, 2016 3:45 am
Perhaps I'm going about this the wrong way.
I have a system object with a number of equations in it. I estimated the system and got resulting coefficients. I did this over a sample period, and would like to forecast using these coefficients outside of the sample period. What's the best way to do this?
Postby EViews Gareth » Mon Mar 14, 2016 8:44 am
Make a model from the system and then solve the model over the period you want to forecast over.
kszynkar
Postby kszynkar » Tue Mar 15, 2016 9:09 am
it works. Thanks
