syntax error
mattandlaura
syntax error
Postby mattandlaura » Tue Mar 08, 2016 9:40 pm
I have created a new eviews9 workfile and when I run a regression in the command line (nr c singd baht ringgit) and I receive a "syntax error." I have attached the eviews workfile. Can anyone help resolve this issue?
natural_rubber.wf1
(24.91 KiB) Downloaded 255 times
Re: syntax error
Postby EViews Gareth » Tue Mar 08, 2016 9:57 pm
What is the exact command you used?
mattandlaura
Re: syntax error
Postby mattandlaura » Wed Mar 09, 2016 4:35 am
The exact command is:
nr c sing baht ringgit
mattandlaura
Re: syntax error
Postby mattandlaura » Wed Mar 09, 2016 4:39 am
Sorry about that, the command is:
mattandlaura
Re: syntax error
Postby mattandlaura » Wed Mar 09, 2016 5:12 am
I found the issue, in the command prompt, i did not use the method, so it should have been
ls nr c singd ringgit baht
for the least square method, sorry about that.
