I'm trying to estimate a model of the form equation myEquation.arch(0,2,ged,z,backcast=0.7) varDep myDummies ar(1) ar(2) sar(3) sar(4) ma(12) ar(12) sar(12)
Question 1 : I read that the minimum value of p (.arch(p,q,options)) should be 1. Does that mean the EViews will replace the 0 by 1?
Question 2 : Feeding initial values do not seem to change the end results. Does that mean that EViews computes its own initial values?
Thanks!
Danny
Questions related to arch model
Re: Questions related to arch model
1) I think that is a typo - we appear to allow p=0 just fine.
2) By default, yes.
2) By default, yes.
Hi Gareth,
Many thanks again for your help.
Danny
Danny
KRITIKA MATHUR
There are way too many iterations to run, Do you know how to edit command line in eviews programme so that I can include an independent variable in the variance equation of GARCH?
1. I need to estimate various ARMA GARCH models
2. I have found a program for running ARMA GARCH with an independent variable in the mean equation (find below - program) along with AR, MA terms in mean
3. Can u check what should be the change in the program so that I can include a variable in the variance equation (i need AR, MA terms in mean equation)
I got program from http://forums.eviews.com/viewtopic.php?f=15&t=1175
I made certain changes, I also saw ftp://economia.unica.it/mattana/Econome ... %20Ref.pdf
Program:
%eqname = "EQ01" 'name of equation object that will be used.
%maxAR = "5" 'maximum number of AR terms
%maxMA = "5" 'maximum number of MA terms
%dep = "R0304" 'dependent variable
%regs = "C W0304 " 'independent variables
%criterion = "@AIC" 'which criterion to use enter "@AIC" for Akaike, "@schwarz" for Schwarz, and @HQ for Hannan-Quinn
!maxAR = @val(%maxAR)
!maxMA = @val(%maxMA)
close {%eqname}
'create table for storing critical values.
%matname = "crits"
if @isobject(%matname) then
%matname = "__crits"
delete {%matname}
endif
endif
table(!maxar+2,!maxma+2) {%matname}
{%matname}(1,1) = "AR / MA"
{%matname}.setlines(1) +b
{%matname}.setlines(a) +r
'set sample
smpl @first+!maxAR @last
!mincrit = 1e12 'set the minimum to an artificially large value to begin
'estimate the models
%arstring = ""
for !i=0 to !maxar
'build up string for AR terms.
if !i>0 then
%arstring = %arstring + " ar(" + @str(!i) + ")"
endif
%mastring = ""
for !j=0 to !maxma
'build up string for MA terms
if !j>0 then
%mastring = %mastring + " ma(" + @str(!j) + ")"
endif
'estimate equation
equation {%eqname}.arch {%dep} {%regs} {%arstring} {%mastring}
'capture criterion
if @upper(%criterion) = "@AIC" then
!crit = {%eqname}.@aic
endif
if @upper(%criterion) = "@SCHWARZ" then
!crit = {%eqname}.@schwarz
endif
if @upper(%criterion) = "@HQ" then
!crit = {%eqname}.@hq
endif
'compare criterion
if !crit < !mincrit then
!mincrit = !crit
!bestAR = !i
!bestMA = !j
%bestARstr = %arstring 'store the best ar string
%bestMAstr = %mastring 'store the best ma string
{%matname}.settextcolor(@all) black 'table formatting.
!ii=!i+2
!jj=!j+2
{%matname}.settextcolor(!ii,!jj) red
endif
{%matname}(!i+2,!j+2) = !crit
{%matname}(!i+2,1) = !i
{%matname}(1,!j+2) = !j
equation {%eqname}.arch {%dep} {%regs} {%bestARstr} {%bestMAstr}
show {%eqname}
show {%matname}
Program:
close {%eqname}
%matname = "crits"
delete {%matname}
endif
endif
'set sample
%arstring = ""
for !i=0 to !maxar
if !i>0 then
endif
%mastring = ""
for !j=0 to !maxma
if !j>0 then
endif
'estimate equation
'capture criterion
endif
endif
endif
'compare criterion
!mincrit = !crit
!bestAR = !i
!bestMA = !j
!ii=!i+2
!jj=!j+2
endif
show {%eqname}
show {%matname}
