Transfering database registry from on laptop to the other
SamChampanhet
Postby SamChampanhet » Tue Feb 23, 2016 8:11 am
Good morning,
Just got EViews 9 on a new laptop. How can I transfer my database registry from my old laptop to the new one?
Thanks,
Sam
Re: Transfering database registry from on laptop to the othe
Postby EViews Jason » Tue Feb 23, 2016 9:09 am
On your old computer:
1.Select Options->General Options.
2.In the dialog select File Locations in the left pane.
3.Press the folder button for Database Registry and Alias Map Path. This folder has all of your database and graph default settings.
If you just want the database registry, copy just the evdb.ini file. You may however want to just copy the entire directory to get your graph settings as well.
Using the same first 3 steps as above on your new computer, place the copies of the desired files into the directory listed in step 3.
SamChampanhet
Postby SamChampanhet » Wed Feb 24, 2016 1:14 am
Thanks a lot Jason!
