When I try to export some FRED time series into my workfile from FRED database, I get a windows error stating the following:
"FRED library error, invalid conversion of NaN to double"
and the import into the workfile fails.
Some exports of the time series work finely, others don't.
Is there a fix for this problem ?
For example, a fetch that does not work is the symbol "ir3tib01huq156n".
FRED error message
Re: FRED error message
What version of EViews are you using and are you up to date (select help->EViews update)?
If you are using EViews 9 which version of FRED are you using? If you select file->open->database, in the database/file type, are you using FRED database or FRED database V1?
I am using Eviews 9 Enterprise edition, update 2015/12/14.
I used FRED database, but I just tried to run the export also in FRED database v1, which did not work either.
Can you try fetching the series again? We haven't been able to replicate the problem.
If you are still having problems, send a screenshot to support@eviews.com and reference this thread
