eq.s options in the rolling regression
nawal
Postby nawal » Mon Dec 07, 2015 6:15 am
I have to check the robustness of my estimates with different time period.
I am using the below code for the same:
if @isobject("comparison") then
delete comparison
endif
'create vector to store r-squares
matrix(6,64) comparison
'create empty equation to be used inside the loop
equation eq
%smpl_start="2000Q1"
%smpl_end= "2015Q2"
smpl {%smpl_start} {%smpl_end} '@last
'get size
!length = @obssmpl
!j=1
for !i = 0 to !length step 1
!j=!j+1
'smpl 1996q1+!i 1996q1+8+!i
smpl {%smpl_start} {%smpl_start}+!i+20
eq.ls 'your model equation
'store coefficients into matrix
colplace(comparison, eq.@coefs, !j)
show comparison
But I am not able to match my model estimates with the results with this code.
I search and found that to get the exact estimates I have to feed the same option which i select when i ran the final model.
Could anyone please help me how to specify eq.ls (options) in the above code.
My estimation settings option is - LS - least squares(NLS and ARMA)
Co-efficient co-variance : Method - Ordinary and information matrix - OPG
d.f adjustment has been ticked
Optimization method - Eviews legacy
Maximum Iterations - 500
Convergence tolerance - 0.0001
ARMA method - CLS
Starting ARMA coefficients values: OLS/TSLS
Backtest MA terms has been tikced.
Below is the Eviews help on the above topic:
http://www.eviews.com/help/helpintro.ht ... 0.068.html
Regards,
Nawal Kashyap
Re: eq.s options in the rolling regression
Postby EViews Gareth » Mon Dec 07, 2015 9:46 am
Not entirely sure I understand the question, but I think what you're asking is how to implement certain options using the LS command.
The help page you link to has all the details.
Or you can estimate an equation interactively, then click on View->Representations to see the command line form (or use the Command Capture window in EV9).
nawal
Postby nawal » Mon Dec 07, 2015 11:26 pm
Hi Gareth,
My question was how to use different LS option in the equation?
The url had all the options, but I have very little knowledge of eviews programming.
So I am not able to implement all the options which I used to estimate my model.
Could you please mention how to write options of my equation in the program?
I would be very thankful to you.
Regards,
Nawal Kashyap
Postby EViews Gareth » Tue Dec 08, 2015 8:40 am
What have you tried?
