What does w{%A}(!i+1) mean in EViews?
windtalker
Postby windtalker » Thu Dec 03, 2015 10:31 pm
Hi guys,
I am new to EViews and need understand a snippet code.
Say I have a for loop like
For %Y 1 2 3 4 5 6 7 8 9 For !i=10 to 20 If w{%Y}(!i+1) <> na then ... NEXT NEXT
What does w{%A}(!i+1) mean? Honestly I tried to figure this out myself but I at least spent 3 hrs but could understand this. I know maybe w{%A}(!i+1) is not correct, if so what does w{%A} mean?
Thanks!
Re: What does w{%A}(!i+1) mean in EViews?
Postby EViews Gareth » Thu Dec 03, 2015 11:17 pm
Impossible to say without knowing what the W objects are.
w{%y} just means that the loop will first run on w1, then w2, and so on.
windtalker
Postby windtalker » Thu Dec 03, 2015 11:23 pm
There is no definition for 'w' before that, but w{%y} appears couple of times in the code.
And, is w{%A}(!i+1) a legal expression? If yes, what is it?
Thank you!
Postby EViews Gareth » Thu Dec 03, 2015 11:45 pm
Yes it is a legal expression. Without knowing what the objects in the workfile are, it is impossible to say what the expression does though.
windtalker
Postby windtalker » Fri Dec 04, 2015 9:28 am
Seems I need to figure out the purples first.
So based on that what should I do if I want to print output to screen?
Say
for !i=1 to 5
How to print each !i to screen?
Thank you!
Postby EViews Gareth » Fri Dec 04, 2015 9:35 am
You could use a statusline command to send the value of !i to the statusline.
Or use a log message.
Postby EViews Glenn » Fri Dec 04, 2015 9:48 am
This may be easier than you think as I'm not sure that you understood Gareth's last answer.
The snippet that you run will do something, where that something will depend on what kind of objects W1, W1, etc. are in the active workfile when you run the code.
So if you have the workfile that is associated with these commands, you can simply look at the icon and determine what type of object you have. From the looks of it, I'd say a probably a vector. But you need to know the context of the program. My guess is that it's just doing something if elements of the vectors W1, W2 are non-missing.
windtalker
Postby windtalker » Fri Dec 04, 2015 10:07 am
That runs too fast on statusline which I could not read each value, but not a big issue.
Thank you again.
So can you point any reference about {}()? It's hard to find the use of it without a key word. At this moment w is unknown but I may find it if I have reference of it and the code purpose.
Postby EViews Gareth » Fri Dec 04, 2015 10:09 am
The () operators change depending on what type of object they are used on.
http://www.eviews.com/help/helpintro.ht ... 04.html%23
windtalker
Postby windtalker » Fri Dec 04, 2015 3:14 pm
Hi...I am using EViews 9
below is my snippet to use logmsg and logsave
For !i=0 to 9 logmsg !i Next logmsg "Mark" logsave E:\\test.txt
No bug reported after I clicked "Run" however the test.txt file in E drive was empty.
How can I write out output to screen or to log file...
Postby EViews Gareth » Fri Dec 04, 2015 3:49 pm
windtalker
Postby windtalker » Fri Dec 04, 2015 3:52 pm
Thanks a lot!
have a great weekend!
