Fetching Forecast Data From Datastream
KUN0
Postby KUN0 » Fri Nov 20, 2015 10:06 am
I'm on a roll....
Fetching IMF data with forecasts is only giving me data through 2015 but there is supposed to be forecast data through 2020. Doesn't work in eviews 8 or 9
Re: Fetching Forecast Data From Datastream
Postby EViews Jason » Fri Nov 20, 2015 12:16 pm
Let us look into it. If however you use, the Zappy servers you do get the forecast data:
dbopen(t=datastreamxml) fetch WDWOGDPDA
Alternatively, you can manually fetch the data
fetch WDWOGDPDA~1980-01-01~:2020-01-01
KUN0
Postby KUN0 » Fri Nov 20, 2015 2:30 pm
We finally moved off Zappy (which is still giving the forecast part without any problems).
It's dataworks which is being a pain...
Postby EViews Jason » Fri Nov 20, 2015 3:15 pm
It doesn't appear to be on the EViews side. I've sent an email to Thomson to see what needs to be done.
KUN0
Postby KUN0 » Tue Nov 24, 2015 11:53 am
Hi Jason. Any updates on this?
Postby EViews Jason » Tue Nov 24, 2015 2:17 pm
We (meaning Thomson and us) are still working on a solution.
This is also more than likely going to require an EViews patch.
KUN0
Postby KUN0 » Thu Nov 26, 2015 12:49 pm
Alright. I'll check back after I spot the next patch. Thanks for looking into this.
Lixir
Contact:
Postby Lixir » Sun Dec 13, 2015 5:31 am
Are there any updates on a solution?
free annual credit report government
Postby EViews Jason » Mon Dec 14, 2015 8:41 am
It is fixed in the next patch.
KUN0
Postby KUN0 » Thu Dec 17, 2015 12:27 pm
Just saw this. Thanks!
