upload series with period
ravage
Postby ravage » Wed Nov 18, 2015 11:47 pm
Small but important (for me) question. How would you upload a series from eViews into a database with a period in it?
Say I have these in eViews:
FHPICLXTAM_IAUS_MGME
FHPICLXTAM_IAUS_MGPE
FHPICLXTAM_IAUS_MGSY
is there any possibility to convert it to
FHPICLXTAM.IAUS_MGME
FHPICLXTAM.IAUS_MGPE
FHPICLXTAM.IAUS_MGSY
as it is uploaded into a fame database?
Re: upload series with period
Postby EViews Jason » Thu Nov 19, 2015 9:47 am
You can with the use of object aliasing in the database. It is a bit cumbersome if you have a lot of series but doable.
Open your FAME database
dbopen(t=fame) myfamedatabase
In the Fame database window, select view->object aliases. Add lines similiar to
myeviewsseries = myfameseries.myfameext
For example,
FHPICLXTAM_IAUS_MGME=FHPICLXTAM.IAUS_MGME FHPICLXTAM_IAUS_MGPE=FHPICLXTAM.IAUS_MGPE
Now if you drag your EViews series from the workfile to the Fame window or if you use the store command (see example below), the series will get renamed.
store myeviewsseries
