Viewing results of two different scenarios on the same graph
Is there a way to see the result of modeling on the endongenous variable using two separate scenarios on the same graph within the model window, or do we have to do this manually in the workfile? Thanks!
Re: Viewing results of two different scenarios on the same graph
You can use the Compare box in the Proc->Make Graph of a Model Object to include different scenarios.
Almost too easy. Great, thanks!
