Insufficient number of observations
Im12345
Postby Im12345 » Fri Nov 06, 2015 8:29 am
Hey everyone,
Everytime I try to estimate the equation, a pop-up screen comes up with 'insufficient number of observations'. However I use a panel-data of 21 countries for 17 years (1996-2012). I use the variables fiscal decentralization and unemployment and I want to make a regression equation of unemployment c fd
But it doesn't work.
I hope you can help.
Thanks in advance
Re: Insufficient number of observations
Postby startz » Fri Nov 06, 2015 9:23 am
You probably don't have enough valid observations. Look at your data.
Im12345
Postby Im12345 » Fri Nov 06, 2015 12:17 pm
Thank you for your answer.
Okay, I do not know a log about eviews, but I think all my data is valid so I do not know how I can see wether they might not be valid.
Postby startz » Fri Nov 06, 2015 12:19 pm
Open a spreadsheet with all the variables in the regression. Then look at each row to see if any are marked NA.
Im12345
Postby Im12345 » Sat Nov 07, 2015 3:15 am
I looked at the variables, however there is never NA, only at the resid, these are all marked as NA. Is this wrong?
Postby startz » Sat Nov 07, 2015 7:07 am
You might want to post your workfile, including the equation you wish to estimate.
Im12345
Postby Im12345 » Sat Nov 07, 2015 7:18 am
This is my workfile that I want to use, this is an excel document, but I do not now how to include the workfile, but hopefully this is also useful for you. I want to estimate
unemployment = c fiscal decentralization(-1)
or
But i do not think it matters which one I want to estimate for the insufficient number of observations screen I get.
Thanks in advance
Panel-data thesis.xlsx
(54.71 KiB) Downloaded 280 times
Postby startz » Sat Nov 07, 2015 7:23 am
It appears that your fd variable is being brought in as an alpha rather than a series. Convert it to a series using the @val() function.
