I am trying to use the @insert function, and it seems to generate errors in even the simplest attempt at using it.
For example, if I have the line:
%mystr = @insert("helo","l",3)
then I get the error message %MYSTR is not defined or is an illegal command
How should I be using this function then?
Thanks in advance,
-cap
@insert function for strings
Re: @insert function for strings
I'm not sure if this is what you want, but
works
alpha mystr = @insert("helo","l",3)-
Looks a bit like a bug to me, I'll investigate.
Thanks startz, that followed up with @elem() does allow me to get the particular string I want.
It would still be nice to see if the original @insert function could be made to work though (thanks Gareth).
-cap
-cap
