Good morning,
I want to import a panel from Excel to Eviews (30 IDs, spanning from 1985 to 2010; the Excel is already structured as a Panel). I have successfully imported the panel using the toolboxes. However, since I may bring modifications to the data I would like to know the command to import a panel... I usually use a command to import regular Excel files and find it easier and faster. Below is the line is usually use:
import c:\users\name\dropbox\thesis\data\Eviews\CM.xlsx range="CM_ip_epolate" @freq A 1985
is it possible to import panel data in a similar fashion?
Thank you!
Import Panel Data - Line of code
Re: Import Panel Data - Line of code
Yes, nothing really changes when it is a panel.
catherinebrunet2
Thank you, it does work!Yes, nothing really changes when it is a panel.
